Bee r install w/ afc help!
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
69
Likes
Okay so I picked up this Bee r from someone on here. I already have an air fuel controller wired in and operating for some time now. Well due to space constraints from already doing a quick splice on the ecu harness for power and ground for the afc I did a quick splice on the power and ground wires of the afc to avoid having too many splice connector up near the ecu connector. Well now my AFC isn’t coming on... okay so I remove the splice connectors completely from the afc’s power and ground to the bee r unit. So the bee r is completely removed and the afc is just as it was prior, yet still afc isn’t coming on. The wires on the afc are not broken or frayed the quick splice only went through the insulation.
Any suggestions?
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
69
Likes
Went to separate ground, swapped green and yellow wires. Works like it should.
