Anyone Know When The OEM 7m Timing Belt Was Discontinued???
plaaya69
87T Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,319
Likes
61
Location
Lake County, IL
#1
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
1,476
Likes
75
Location
MKE, WI
#3
Is the gates belt just old? Curious why you are changing it out
plaaya69
87T Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,319
Likes
61
Location
Lake County, IL
#4
Good to know, thanks for the part numbers.
I never cared the blue powdery rubber coating on the exterior of the belt from day 1. That coating came off very easy even when handling it by hand and leaves a very fine very light blue power mess over some time. I will be running clear timing covers and would like them to stay as clean as they can be for as long as possible.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
1,476
Likes
75
Location
MKE, WI
#5
Ah interesting, I will steer clear of that gates "High Performance" belt then.
Probably not worth the cost.
suprarx7nut
YotaMD.com author
Authorized Seller
Joined
Nov 10, 2006
Messages
3,988
Likes
Location
Arizona
#6
How about the Greddy one? I as eyeing an upgraded belt of some kind. I'm fine with OEM if there's no real benefit to the aftermarket, but thought the upgraded ones were actually better reinforced.
http://www.greddy.com/products/engine/timing-belts/
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
1,476
Likes
75
Location
MKE, WI
#7
Yeah they are supposedly better reinforced with synthetic aramaid fibers.
Though I have never seen any issues with the stock Toyota belts.
Unless you are running some crazy high spring rates on the valvetrain its probably not going to matter much.
Somewhat related but off topic note that comes to mind:
https://www.enginelabs.com/engine-tech/project-spinal-tap-ii-the-valvetrain-dynamics-of-11000-rpm/
These guys are running valve springs with an open load of 1,230 pounds to prevent float / bounce at 11,000 RPM.
That kind of force would need some serious torque to spin the camshaft. (Though not as much of an issue with that aspect since chain driven.)
A good read nonetheless.
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
67
Likes
i just bought one from Toyota today man. List price on it was $44.31, I got it for 33.23 through work. The idler was on back order too but it only took 3 days to get. The only thing they didn't have was the oil pulley
plaaya69
87T Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,319
Likes
61
Location
Lake County, IL
#9
If I had to do it again I would have just stuck with the Toyota brand but I am doing it again now so it's kinda like a fresh start again lol.
From what I have heard in the past there is one supplier for the HKS, Greddy and Gates Racing 7m timing belts but I do not know if that is true or not. I am going back to the Toyota one because I never really heard of any failures even with higher HP.
I just ordered a OEM timing belt today, thanks for the heads up.
