Another 7M ground up build
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
357
Location
Yorkville, IL
Ok my EMU is set up as a 66-3 trigger setting and im seeing that the stock cps is a 24-1, 24 teeth on the cps and 1 on the crank.. Are these settings messed up also??? getting frustrated.
andrew_mx83
Authorized Seller
Joined
Mar 22, 2008
Messages
177
Location
Melbourne, Australia
Yes those settings are messed up, tell it the crank is 24 teeth, and the cam sync is 1 tooth.
You will also have to tell it where the 1 cam sync tooth is in relation to TDC.
You will also have to tell it the wheels are spinning at cam speed (not crank speed).
Btw 24-1 refers to a single 24 tooth wheel with 1 missing tooth as a TDC reference, which is not what the 7m CPS has.
If you are running without cam sync (waste spark, batch injection) you only need 1 wheel but it needs a missing tooth so the ecu knows when it rolls past TDC which becomes the basis of all the injection and ignition timing.
For full sequential, the cam sync tells it when it's at TDC on the compression stroke and the 24 tooth wheel tells it exactly where it is in between so a missing tooth is not required.
I'm running batch/waste on mine so I just ground 1 tooth off the 24 wheel and ignored the cam pickups.
Hope that helps!
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
357
Location
Yorkville, IL
That helps thank you for clarifying. I ordered a fitting for the fuel feed so I can run stainless an line so once that comes in tomorrow I can try to start it again.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,595
Location
Shakopee, Minnesota
I was about to say
the CPS is 24 tooth. No missing teeth.
depending on the EMS:
Crank Ref: 24
Cam Sync: 1
Of note is that Crank Ref will be called different things by different companies. As an example, MoTec calls it Ref Sync crankshaft Teeth. though in the hundred series is was called Crank Ref Sync mode and M1 is Engine Speed Reference Mode.
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
357
Location
Yorkville, IL
It ran shitty at first but I trimmed the injectors and lowered fuel pressure based off the wideband reading and it’s idling smooth at 1100rpm, I’ll tinker with that some more tomorrow.
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,595
Location
Shakopee, Minnesota
How big are your injectors? you should not need to lower fuel pressure unless the injectors are in that weird spot that causes pintle bounce usually around the 1.5ms range. Are you running them fully sequential?
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
357
Location
Yorkville, IL
Question, checked the timing with a timing light and it was at 15 degree and I set the lock angle at 10. Do you still adjust this via the cps? There’s no diag mode like stock so I’m not 100% on how to adjust from here.
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
357
Location
Yorkville, IL
I should add also it fires right up. Faster than ever before, I’d have to think that’s a benefit of putting new coils in the cps
  • Like
Reactions: plaaya69
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
357
Location
Yorkville, IL
Drove the Supra to the gas station today! ‘twas a success! Brembo Mercedes Brakes went on flawlessly, coilovers in. Need to get this puppy tuned so I can enjoy it some this year!
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,350
Location
MKE, WI
Those brakes in the front + the evo rear full floating calipers on my Supra are incredible.
Hands down the best feeling brakes I've ever experienced.
Plus when I come home they are hardly hot at all.
Enough cooling for some serious braking work.
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
357
Location
Yorkville, IL
Going to give the driftmotion remote tuning a try. Having the ability to pull onto a lift between pulls without paying “shop time” if needed could be a benefit.
  • Like
Reactions: debrucer
Z06gette
Authorized Seller
Joined
Apr 29, 2018
Messages
357
Location
Yorkville, IL
Took the car out for a 20 minute back roads cruise. I’m impressed lol I’ve made some tweaks to the base tune it’s idling and driving pretty good. Only pumped about 5psi through her and kept it under 4K rpm with lots of decels
  • Like
Reactions: Piratetip
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,350
Location
MKE, WI
Yup, break it in right.
Varying RPM, lots of decel, decent moderate load.
Don't be nice to it, and don't cruise at constant rpm on the hwy.
Get those rings seated right early and you will be happy down the road when compression is still high & not consuming oil / excessive blowby.
  • Like
Reactions: Z06gette
figgie
Well-Known Member
Authorized Seller
Contributor
Joined
Messages
5,595
Location
Shakopee, Minnesota
If you put the ignition lock at 10 and timing light shows 15.
In the software, there is a place to adjust the timing to match the lock.
  • Like
Reactions: Z06gette
