Aftermarket traction arm?
Kristian_Wraae
Authorized Seller
Joined
May 18, 2007
Messages
724
Location
Aarhus
Does anyone apart from Battle Version make aftermarket traction arms ?
Lipp made one, but it is no longer available.
I'd like a beefier setup, but it has to look more stock than Battler Version. We have visual inspection every two years and you are not allowed to change anything - even if it is for the better.... So nothing adjustable and no Heim joints.
The Lipp Steel ones were nice (heavy though). Also if anyone knows where to get a set let me know.
Piratetip
Far From Maddening Crowds
Authorized Seller
Joined
Dec 30, 2005
Messages
2,174
Location
MKE, WI
I have a second set of OEM traction arms.
Once I cut the steel sheets and reinforce them with my TIG welder, I will post up my findings.
Not interested in anything currently offered in aftermarket.
Heim joints aren't suitable on the street for a daily driver IMO.
My suspicion is the small amount of wheel hop I still have present even after swapping out every suspension and subframe bushing is attributed to the traction arms flexing and popping back straight over and over.
The reinforments I am going to add will help prevent this.
Asterix
Lurker of Power
Authorized Seller
Joined
Messages
524
Location
Vienna, VA
Fornari also made the trailing link (strut rod) to upright joint single shear instead of double, which scares me away. That also changes the geometry.
Piratetip
Authorized Seller
Joined
Dec 30, 2005
Messages
2,174
Location
MKE, WI
Aftermarket parts manufacturers aren't the best as far as engineering to any kind of requirements.
It's more of a - slap parts together and see what sticks.
Case in point bent A1 "upgraded" arms.
