87 7mgte No Spark Issue
Joined
Mar 7, 2019
Messages
Likes
Hello, New to this whole forum thing so yell at me its fine..
Got an 87 Mk3 with a 7mgte & R154 in it. Car had been sitting for 10+ years in a garage and from the original owners knowledge was running when he bought it. He brought it home and started taking it apart and it hasn't left that spot since. When I first got the car a week ago I went through and changed the Oil, Coolant, Clutch Fluid, Clutch Slave Cylinder ( since the fitting was leaking I replaced the line and cylinder), Brake Fluid, Spark Plugs, & Tranny Fluid. I also used a evaporust to clean the tank and replaced the old fuel pump with a Walbro 255 & new filter.
Tried cranking it over after all the fluids were swapped and it would only turn over very slow. I used a diagram to check all the vac lines and make sure they were correct. After still having a slow crank, I replaced the starter with a new one and it sounds great. Tried to start her and nothing. I know Im getting good fuel pressure since the fuel rail had a slight leak I had to fix. Next I tried doing some testing to the ignition system and could not get any spark from the plugs. I looked through the manual and tested the coil packs, high tension wires & the CPS. The results were:
Coil packs tested around 1 Ohm when the manual states .3-.6 Ohms
High Tension Wires checked out okay
The Cam Position Sensor - I got no reading from the G1-G points, I got 154 Ohms on G2-G & Ne-G
My ignitor looks in rough shape and with the tested CPS I think it could have 1 bad sensor? Anyone else have an issue like this?
Im ISO a used CPS now to try and replace that and see if that will fix the problem.
supraguy@aol
Authorized Seller
Joined
Dec 30, 2005
Messages
4,229
Likes
Location
Atlanta
#2
I think you're beginning in the right place. Find a good(known working) cps, and see if you get spark.
PS- This is Diego from the FB supra page.
3p141592654
90T
Authorized Seller
Contributor
Joined
Oct 11, 2005
Messages
4,084
Likes
64
Location
Thousand Oaks, CA
#3
Make sure the CEL is on with the ignition on verifying power to the ECU.
When cranking check if the tach is moving. If its dead, then you have a CPS, ECU, ignitor issue.
I would start by looking for broken and damaged wiring at the CPS connector. The heat destroys the wire insulation and connector parts leading to problems.
