86.5 na vs 91 turbo?
dpkeefe11
Authorized Seller
Joined
Sep 27, 2012
Messages
59
Location
blackstone, massachusetts
1983 Toyota Supra 0-60 mph 8.8 Quarter mile 16.6
1984 Toyota Supra 0-60 mph 8.5 Quarter mile 16.5
1986 Toyota Supra 0-60 mph 6.9 Quarter mile 15.2
1988 Toyota Supra 0-60 mph 7.8 Quarter mile16.0
1989 Toyota Supra Turbo 0-60 mph 6.5 Quarter mile 15.0
1991 Toyota Supra Turbo 0-60 mph 7.0 Quarter mile 15.4
1993 Toyota Supra Turbo 0-60 mph 4.5 Quarter mile 12.9
1994 Toyota Supra 0-60 mph 6.8 Quarter mile 15.0
dpkeefe11
Authorized Seller
Joined
Sep 27, 2012
Messages
59
Location
1983 Toyota Supra 8.9 16.8
1984 Toyota Supra 8.7 16.8
1986 Toyota Supra 7.0 15.4
1988 Toyota Supra 7.9 16.0
1989 Toyota Supra Turbo 6.6 15.2
1991 Toyota Supra Turbo 7.1 15.6
1993 Toyota Supra Turbo 4.6 13.1 (C&D Mar '93)
1994 Toyota Supra 6.9 15.2
1994 Toyota Supra Turbo 5.3 13.7
1995 Toyota Supra Turbo 5.1 13.5
1997 Toyota Supra Turbo 5.1 13.
3p141592654
90T
Authorized Seller
Contributor
Joined
Oct 11, 2005
Messages
4,167
Location
Thousand Oaks, CA
Because they were not all tested by the same equipment, in the same location, with the same driver and driving style, air temperature and humidity, etc. You can take any model vehicle and find an easy 25% variability in 0-60 times for the same vehicle. Consumer reports is usually very slow, C&D is typically fast. Your list has absolutely no verifiability as to source or conditions, so what do you expect?
Authorized Seller
Joined
Apr 17, 2007
Messages
12,768
Location
Tokyo,jp
1986 is a mk2. 1986.5 is a mk3.
Insidious Surmiser
<i>Formerly 89jdm7m
Authorized Seller
Joined
May 12, 2006
Messages
2,172
Location
Oceanfront
Alls i was asking here is why would it be? just because of weight or what?
weight and gearing... also gearbox as well... were these auto or manual, who knows?
too many variables to be sure... what we do know though is that the 86.5 is the lightest of the mk3's, we also know what gearing each year model came with from the factory... just do your research, the info is there
Authorized Seller
Contributor
Joined
Messages
8,813
Location
why is it that the 86.5 na is faster than a 91 turbo? since it involves both a turbo and non turbo i thought ide ask here
Want to make a wager? I even have a stock valve bodied, stock torque converter A340E equiped 91 turbo.
Dan_Gyoba
Turbo Swapper
Authorized Seller
Joined
Aug 9, 2007
Messages
1,836
Location
Alberta
Where in there does it state auto or manual transmission? With a manual, the turbo isn't as much of an advantage in the 1320, though it should still be faster.
The turbo gets taller rear end gears, even taller after 1989, which won't help quarter mile times. They also might have taken something with a different set of options. Even if it's the same magazine testing the cars, there are still a lot of variables.
From our point of view now though the difference that we should care about is the potential power that each will have on the same budget.
