7MGTE Fuel system upgrade questions...
plaaya69
87T Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,318
Likes
59
Location
Lake County, IL
#2
Most likely if you are running a aftermarket adjustable fuel pressure regulator you want a direct vacuum line with no interruptions, that vsv will get in the way. When I was on the OEM computer and running a Aeromotive fuel pressure regulator I left that vsv disconnected and ran direct vacuum to it. No codes and no problems for me.
shadowman1977
Authorized Seller
Joined
Jun 4, 2015
Messages
166
Likes
5
Location
Kingston N.Y. 12401
#3
Awesome!
Thank you for the information.
Bmettie
Authorized Seller
Joined
Apr 27, 2010
Messages
197
Likes
Location
Florida
#4
On the stock ECU its for hot starts only. It'll disconnect the vac source so there is higher rail pressure.
shadowman1977
Authorized Seller
Joined
Jun 4, 2015
Messages
166
Likes
5
Location
Kingston N.Y. 12401
#6
Hey all.
  • So....after replacing the aem 240 lph fuel pump with a 300 (cause it came with a copper washer and the housing was aluminum and I broke the housing) I powered up the pump without the car running. And after air was cycled out the pumps pressure spiked and pump speed slowed down so I stopped.
Not sure what the procedures are for trying to start a Supra when it hasn't been run since I had it, and a lot of aftermarket parts were installed, like the adjustable fpr. Dont wanna’ destroy anything.
No leaks, fuel is cycling back to the pump. Was watching inside the fuel cell while I powered the pump.
I have two f.p. guages, one after the pump before the inline filter and one after the rail. The rail guage after the fpr is showing no pressure when I run the pump with a power probe with the vehicle off.
Any incite would be greatly appreciated.
