7mge internals with 60-1 turbo how much boost can I run?
nixon662
Authorized Seller
Joined
Apr 21, 2014
Messages
15
Location
alberta
Hey guys, ive had so much info from here and decided I should just post. Have some questions about my build and its capabilities. Hope someone has some senior input as not many people around here do this.
89 usdm supra turbo 5-speed
Lexus afm/550cc upgrade
Walbro 255
Safc fuel controller
Innovate lc-2 wideband
New gte block, stock GE pistons
Cometic metal head gasket
9.4:1 compression
Rebuilt head,all new everything
Act 6 puck clutch
60-1 ct-26 upgrade
Upgraded intercooler
Knock off hks atmospheric bov
3" straight pipe exhaust
Got the car started today and it sounds great! Engine is missing a bit and it doesnt want to idle for more than 2 to 4 minutes. I am guessing I need to adjust my timing? Im not sure if my grandfather's timing gun works for fuel injection lol. Its quite old.
Also have an issue with air/fuel. At idle I read 9.4-9.6.
I would like to boost to 10lbs maybe a bit more if possible once I get my ratio correct.
Is this possible? How do I achieve these power goals?
IndigoMKII
Authorized Seller
Joined
May 9, 2011
Messages
2,181
Location
Madison, Virginia
With a walbro 255 or bigger, you need to run an aftermarket fuel pressure regulator as the stock one doesn't flow enough. Since the stock FPR doesn't flow enough, it builds more pressure in the rail than needed.
When you get the fuel system fixed, you could probably run 14 PSI at 9.4:1 compression on 93 before it starts pinging.
suprarx7nut
YotaMD.com author
Authorized Seller
Joined
Nov 10, 2006
Messages
4,140
Location
Arizona
You definitely need to sort out the tune and ignition timing before going any further. With that size turbo and the ge compression you don't have much room for error.
That'll be a blast when you've got it tuned up though. Cre let me drive his turbo ge motor and that thing had some snappy power. What a blast.
Its probably worth buying a nice timing gun.
Sent from my Moto X.
nixon662
Authorized Seller
Joined
Apr 21, 2014
Messages
15
Location
alberta
Ok whooa whats pinging? I forgot to mention the fuel pressure regulator and its set at 30 psi as it was on the previous motor.
And as for the tune I am hoping the safc will be accurate enough to prevent detonation due to lean condition. As long as I run rich while boosting can I boost up on those pistons?
Cheers :)
IndigoMKII
Authorized Seller
Joined
May 9, 2011
Messages
2,181
Location
Madison, Virginia
Cheers :)
Not necessarily. What electronics are these on? GE or GTE. The stock timing maps is what will make this a time bomb unless done properly. I'm not too familiar with the difference between the GE and GTE timing maps but on a GTE with that much compression, the timing might be too aggressive for the way the 60-1 will spool with the extra compression helping.
And pinging is detonation, you'll hear the valves rattle a little bit. It's from the timing being too aggressive with the octane of fuel used. Take a car and put in 87 octane when he should be running 89 or higher. On a slight incline at moderate loads, you'll hear a slight pinging and the valves chattering.
nixon662
Authorized Seller
Joined
Apr 21, 2014
Messages
15
Location
alberta
Its on gte electronics. I do hear some noise from the head sounds like valve ticking or a spark plug/wire constantly shorting out. So how would I get around thw aggresive timing? I am going to buy a goos timing gun right now. And was gonna try lucas oil stabilizer to help valve noise.
Also this morning I pulled it out of the garage and revved it slightly. Oil sprayed out the exhaust about 5 feet all over the driveway. Turbo seals? Its been sitting off the car since August last year. Buddy has a stock turbo for me ill be picking up today
Authorized Seller
Contributor
Joined
Messages
8,812
Location
Don't waste your money on oil additives. All name brands in your area come from the same refinery in your area with different labels and all the requirements set by the API and SAE to meet the labels description. You need to fix the problem if you have valve noise.
nixon662
Authorized Seller
Joined
Apr 21, 2014
Messages
15
Location
alberta
Got the fire extinguisher handy just incase haha but i would also like a video if it did happen. And i will share of course.
Just went for a spin around the close and fuel gets cut at 2000 rpm. Also have a code 31. Had a code 11 earlier today but replaced batt terminals and It went away.
When I timed it the notch was past the 15° mark so I adjusted cps until it moved to the 10° mark and still seems out of time a bit.
Also had a small backfire in 2nd when I let off the throttle. Never had rpm above 2000... could it be from the aggresive timing? Is the safc even capable of correcting this?
Thx
suprarx7nut
YotaMD.com author
Authorized Seller
Joined
Nov 10, 2006
Messages
4,140
Location
Arizona
I'm not sure how you're hitting fuel cut so easily with the lex AFM. Something doesn't seem right. What kind of boost are you running now?
nixon662
Authorized Seller
Joined
Apr 21, 2014
Messages
15
Location
alberta
Hey sorry for the late reply got busy with other things, i did not jump those terminals when i timed it and now it appears to be more than 20 degrees btdc. So should i redo my timing? It is running now but the air fuel ratios keep fluctuating between 10 and 16. And when I let off the throttle it seems to max out at 22. Wierd..
Also im getting a dyno tune as soon as I get 700 kms on the motor. Cant wait to see what i can get out of it!
suprarx7nut
YotaMD.com author
Authorized Seller
Joined
Nov 10, 2006
Messages
4,140
Location
Arizona
Yes, definitely reset your timing. 20 is way too advanced. Back it off to 10 with the terminals jumpered and slowly advance it form there if you really want to. Personally, I'd just leave it at 10. My idle gets less and less smooth the further from 10 I go, plus you've got a few other complications to sort out before you start advancing the timing significantly.
22 is normally the max an AFR gauge will read. It means the AFR is 22 or higher. The 7M ECUs go very lean when you let off the throttle (because there is no/little demand for fuel). That's normal.
Report back on the dyno results. Should be interesting.
nixon662
Authorized Seller
Joined
Apr 21, 2014
Messages
15
Location
alberta
Just going through my old posts and wow. I had some really bad ideas haha.
Update, 60-1 turbo never really worked from cx racing. Once i got the 57 trim from driftmotion and fixed the wiring on the car, everything was good.
Knock sensors had to be re-wired with shielded cable to ecu, and the CPS wiring was causing me all my other problems. I ended up rebuilding that engine with GTE internals and raised the compression a bit. I was running the 57 trim for 3 years at around 12 psi no issues. Motor is still strong.
Rear subframe cracked. Fuel tank started leaking. Dropping the rear end and replacing everything this month. Been having a hard time finding a fuel tank though.
Anyway i appreciate this site and all the people who contribute to it. Helped me alot these last 6 years
plaaya69
86.5 Turbo Converted Supra
Authorized Seller
Contributor
Joined
Nov 18, 2006
Messages
1,525
Location
Lake County, IL
Try Car-Part.com . It searches junkyards all over the US and will show prices most of the time for parts but sometimes you have to call the junkyard that has the part. Sometimes ebaymotors will have a gas tank for sale but shipping costs can be quite high.
nixon662
Authorized Seller
Joined
Apr 21, 2014
Messages
15
Location
alberta
Yes i searched car part and nothing shows up. Submitted a request form and got one reply. Turns out they cannot ship across the border. So ill be checking all the wrecking yards in alberta for the next few months. lol
