7mge ct26
donnie N.
Authorized Seller
Joined
Apr 16, 2013
Messages
8
Location
Olympia,WA
This has been talked about youll find it in the forum na to turbo conversion its alot of work. good luck
WyoMK3
Authorized Seller
Joined
Oct 2, 2012
Messages
28
Location
Sonora, TX
I had mine done in a few weekends worth of work. But I had a turbo donor car. the cheapest way from where your at would be a gte exhaust manifold, downpipe and custom feed/ return lines. But dont expect it to live long, the NA ecu is not good to run with a turbo. short of doing a gte swap you basically need everything but the long block. some will say to swap cams too. but that's up to you.
