2jzge TPS with 7m ecu
GreenChevelleSS
Danny
Authorized Seller
Joined
Dec 17, 2005
Messages
518
Likes
Location
Tulsa, okiehoma
#1
In the middle of a 2jzge swap into my 92, running the 7m wiring and ecu. Will the 2jzge TPS work with the 7m? I looked at the wiring and it shows the 2jz tps to have a vta2 instead of an idle switch. so that means 2 potentiometers in the tps instead of one and a switch
Zazzn
l33t M0derat0r (On some other forum) n00blet here
Authorized Seller
Joined
Messages
956
Likes
Location
Toronto/Bay area
#2
No it will not work, I measured the resistance values and they are off, I also believe the voltages will be wrong for the ecu.
You can try but i'm sure it will not work.
Was trying to do the opposite. Use a 7m TPS on a 2jz ECU.
GreenChevelleSS
Danny
Authorized Seller
Joined
Dec 17, 2005
Messages
518
Likes
Location
Tulsa, okiehoma
#3
makes sense. I got the part number off my TPS and its the 91-97 sc300 not the 98+ like i thought. My wiring is 98+ so thats why i used that diagram. we will see but i think your right.
