2JZ GE VVTi
kcollymore
Authorized Seller
Joined
Jul 23, 2011
Messages
17
Location
Trinidad
Good day guys I currently have a 2JZ GE VVTi in a Toyota crown and recently the engine check light comes on when I kick down and the cars remains on but when I mash the gas peddle I get no response, if I drive slow without using the kick down the car will drive good until after driving for an hour straight then the check light will come on and the car cuts off, if I then leave the car off for 5 minutes it will drive normal for a bit then the check light comes on again.
I had change the crank sensor and the cam sensor already and same problem.
A70nut
Authorized Seller
Joined
Sep 21, 2018
Messages
219
Location
Lexington, Ky
Any codes in the ecu? If it's a 2jzgevvti I would assume the car is obd2? Checking for codes would make assistance much easier.
