1uz how to and parts list???
BOOSTCRAZY
Authorized Seller
Joined
Oct 28, 2010
Messages
Likes
Location
FINDLAY, OH
#1
i found a few threads about 1UZ swapped cars but does anyone know of a step by step how to thread with parts list like we have for the jz swaps. any help would be appreciated. thanks
Chambers
Now you know
Authorized Seller
Contributor
Joined
Sep 9, 2007
Messages
981
Likes
Location
Baltimore County, Maryland
#2
Off the top of my head for my car:
1UZ-FE From Oil Pan to ECU
W58
W58 cross member
W58 shifter
W58 driveshaft
Quantum Auto W58 Adapter kit
-QA Flywheel
-QA Clutch disk and pressure plate
-QA Slave cylinder/throw out bearing spacer
-QA Clutch Lines
-Bell housing to adapter plate bolts
-Pilot Bearing
1JZ-GTE ARP flywheel bolts
7M-GE pressure plate bolts
Quarter Master slave cylinder/throw out bearing #721-100
Engine mounts
Extend Alt power and regulator wires
Use 1UZ radiator and heater hoses
-Flipped long hose upside down and trimmed accordingly
-Short hose trimmed accordingly
-Extended drivers side heater hose
-Passenger side heater hose was good
Throttle cable from a early 90's Celica
Use stock Supra radiator with electric fans
7M Oil pressure sensor
-Removed the oil pressure switch (dummy light)
-Replaced with 7M sensor
Rear o2 sensor simulators
-4 Resistors # 271-133 (2 packs) 50 ohm wirewond resistors 10watt
-Diod Heat sinks
-Thermo paste
-Super glue
1986 Toyota Truck 4cyl brake booster
Tach driver from a 80’s celica
-Havent found one exactly right yet tho
I believe that’s it for my car...
BOOSTCRAZY
Authorized Seller
Joined
Oct 28, 2010
Messages
Likes
Location
FINDLAY, OH
#3
Thanks a lot 4 the parts list. Can u tell me the best place to find a pinout diagram for wiring up the engine into the chassis (please a link). thanks
