1JZ with 6262 turbo and .58 exhaust housing limit
A70nut
Joined
Sep 21, 2018
Messages
Likes
Location
Lexington, Ky
#1
I have used the search function to no avail, so now I have come to making a post. The car is a 1jz non vvti with 272 cams and a 6262 turbo with a .58 exhaust housing currently. I'm going standalone in the spring and was wondering if that exhaust housing is going to limit me while trying to make 500ish whp?
JDMMA70
Authorized Seller
Joined
Dec 4, 2006
Messages
2,636
Likes
12
Location
Houston
#2
You might make somewhere close to 500 but that is a small rear turbine housing. Id suspect 450 perhaps a little more
Zazzn
OLD school
Authorized Seller
Joined
Messages
1,023
Likes
12
Location
Toronto / San Francisco
#4
.58 will hurt top end at the upper limits but less then you would think. Maybe 100 WHP off the top vs .58 / 1.0 AR
A70nut
Joined
Sep 21, 2018
Messages
Likes
Location
Lexington, Ky
#6
Ah. Ok, I'm just a bit concerned because I haven't seemed to see any dyno sheets of anyone with a .58 hot side and I dont know what kind of power it will be killing up top. I'd love to see some 500+whp dyno sheets with that exhaust side just so I know it can be done.
A70nut
Joined
Sep 21, 2018
Messages
Likes
Location
Lexington, Ky
#8
Ok, I think I'll just see what it does with the .58 housing and change to the .7 next winter if I feel I need more, thanks!
Authorized Seller
Joined
Messages
15,015
Likes
Location
Seems like the .58 is going to make your car a rolling smoke show. That 6262 will spool so quick with that small a rear housing, I feel you're going to have no traction. I would think you'd want a .81 or something closer to that.
A70nut
Joined
Sep 21, 2018
Messages
Likes
Location
Lexington, Ky
#10
Yeah, I'm sure it'll hit hard, but I plan on roadcoursing and autocrossing the car this upcoming season and I want the response to be as good as I can get it without a quickspool valve or a smaller turbo. I love the response around town too, positive boost by 2500rpm makes it a bit better to cruise around.
Likes: XofXtimeX
Authorized Seller
Joined
Apr 17, 2007
Messages
12,662
Likes
10
Location
Orange, CA
#11
With the 272 you can rev to 8-9k. So full spool by 3500-4K is not bad when Revving that high.
twin2turbo
Authorized Seller
Joined
Apr 1, 2010
Messages
66
Likes
Location
Mill Creek, Wa
#12
I recommend getting a some more valve train components than just 272 if you're gonna turn out 9k. Also you have to remember that the power band will shift right with cams so you're not gonna see that full boost at 3500 unless you have a ridiculous small turbo.
My 1j is setup to turn 10k but I have a alot of work done to achieve that.
A70nut
Joined
Sep 21, 2018
Messages
Likes
Location
Lexington, Ky
#13
This is the reason I want to keep a small rear housing, I start making boost low, but because of the cams shifting the power band, power still doesn't come on hard until just over 4,000 rpms(currently untuned onstock ecu though).
twin2turbo
Authorized Seller
Joined
Apr 1, 2010
Messages
66
Likes
Location
Mill Creek, Wa
#14
A new turbine housing is only like $250, I'd see what you can do and if you're not satisfied get a bigger housing and try that out. Also never hurts to have options
A70nut
Joined
Sep 21, 2018
Messages
Likes
Location
Lexington, Ky
#15
Yeah I have a .70 that I took off to put this on so I'll go back to that if this doesn't keep me happy, but I'd rather give up a little power up top for a bit of area under the curve down low.
Zazzn
OLD school
Authorized Seller
Joined
Messages
1,023
Likes
12
Location
#16
Seems like the .58 is going to make your car a rolling smoke show. That 6262 will spool so quick with that small a rear housing, I feel you're going to have no traction. I would think you'd want a .81 or something close to that.
complete opposite, you'll be able to control the throttle much more linear. With a .81 it will be an on-off switch frying tires for sure.
On my old sp63 on my 7m I used to get 15 PSI in 5th at 3500 rpm with a .58, however then I changed it to a .70 and a .84. The .58 certainly makes the car more controllable vs the .84. The bigger ar's act like an on-off switch. They really don't change the boost threshold at all they simply help the car get a few pounds of boost before you hit the threshold.
Blackdawg
Taco Soup..my rides
Authorized Seller
Joined
Oct 12, 2010
Messages
255
Likes
Location
Wyoming
#17
Keep it under .7 if your auto crossing and driving around town mostly. Be way more fun that way. If anything a .63 housing would be a good middle ground perhaps. But I'd leave the .58 on there
