1JZ vs 2JZ question
87M-GTE
Slow
Authorized Seller
Joined
Sep 12, 2007
Messages
1,705
Likes
Location
Milwaukee WI
#1
I have a few questions about the interchangability of these two engines:
-Is the cylinder bore of both the 1jz and 2jz engines the same? If so can the 2jz pistons be used in place of the 1jz stockers? Would the performance be effected?
-Is the "stroke" gain of the 2jz achieved by crankshaft lift or connecting rod height?
-So, would a 2jz crankshaft, rods , or pistons be able to be used in a 1jz block? And what what benefits would be yielded?
Thanks
Sam
soapra
Authorized Seller
Contributor
Joined
Apr 6, 2005
Messages
860
Likes
Location
VVTi'n, CA
#2
Bore size is the same, but In Japan the 1jz pistons are considered an upgrade over the 2jz pistons. Crank on the 2jz is 86mm stroke vs. the 1jz is 71mm or 72mm I don’t remember right this moment. The bore size is the same 86mm. the Deck of the 2jz block is taller to accommodate the longer rods.
Supra-Man18
Authorized Seller
Joined
Nov 24, 2007
Messages
357
Likes
Location
miami
#3
Just wondering, how are the 1jz pistons an upgrade to the 2jz ?
soapra
Authorized Seller
Contributor
Joined
Apr 6, 2005
Messages
860
Likes
Location
VVTi'n, CA
#5
The 1jz pistons have shorter skirts and are lighter. I think compression changes also. I have never cc'ed a 2jz block with a 1jz piston, maybe I will try it, to give you an accurate number.
