1000hp 7m? parts list?
89mkiii18
Authorized Seller
Joined
Sep 28, 2006
Messages
15
Likes
Location
st pete
#1
hmm ok well i have owned my supra now for about 2 years i love this car and could never buy anything better iv dumped a decent amount of money into it to restore the interior and body and what not and have made 365 horse power and 387flbt its a fun car but you always want more...well i just got a huge settlement from my grandmother and its time to build that 7m with 1000 horse power but i need some help getting there i want a streetable car meaning suspension wise i have it down with tien flex coilovers/in car electronic adjustability i have tsw wheels 3 inch lip in the back 1 inch in the front its set for a road coarse but i want to build the motor a little more...heres a parts list i put together that will probably need adjusting let me know....
-Dual q-trim ball bearing GT80 turbo from wotm(supports 1200hp)
-Greddy 4 row front mount
-2.5?3.0 intercooler piping? suggestions?
-hks ssq bov
-hks gtII waste gate
-Titan motorsports ported and polished head
-oversized valves
-teds components 12mm 280 lift exhaust and intake cam
-all titanium valvetrain
-crower forged pistons
-cp .040 oversized pistons
-titan motorsports cncd main caps
-clevite bearings
-electric waterpump with secondary and relay
-dual flexlite fans
-4 core rad.
-egr delete
-oil overflow tank (2qt.)
-aem ems stand alone
-aem tru-glow boost guage/controller
-greddy turbo timer
-gm 5 bar map sensor
-75mm throttle body
-ported and polished intake
-3.5 inch exhaust (stainless)
also in my parts like im going to include wilwood 13.5 inch rotors and 6 piston up front and 4 in the rear i have hotchkis sway bars adjustable end links cncd unibody bushings welded rearend and shot peend and hardend axles, one peice drive shaft lmk what you guys think
Slow_Sc3
I beat bikes dude
Authorized Seller
Joined
Apr 2, 2005
Messages
401
Likes
Location
Maryland
#6
and dont forget one of those front facing intake manifolds and use 3 inch intercooler piping it will be easier to work with that turbo / front mount / throttle body.
Authorized Seller
Joined
Messages
14,974
Likes
Location
Why 1000 hp? Why not 2000?
1000 horsepower is a bit extreme if you plan on driving it any where but the track. You should really focus on a streetable 500-600 rwhp. If you're building a dyno queen or track car then I guess you can build it as high horsepowere'd as you'd like.
There are a few guys on here running around 700-850 rwhp on a 7m. You may want to check out their thread. Good luck.
Slow66
I think with my dipstick
Authorized Seller
Contributor
Joined
Apr 3, 2005
Messages
1,457
Likes
Location
Newington, CT
#8
For the IC piping, 3" from turbo to IC, 4" from IC to tb, ditch the 75mm tb for a 90mm tb. Why are you going .040 over? Bore as little as possible to keep meat on the block. The head will need extensive modifications for those cams. You're gonna need some sort of turbo header, and a Front facing style manifold, and a wicked fuel system.....shoudl i keep going??
Not trying to be a dick, but you got alot more to think about, and i'm speaking from experience....
89mkiii18
Authorized Seller
Joined
Sep 28, 2006
Messages
15
Likes
Location
st pete
#9
understood this is why im asking i also own a 800 horse transam gta so i know what is like to go fast :)
89mkiii18
Authorized Seller
Joined
Sep 28, 2006
Messages
15
Likes
Location
st pete
#11
yea i had the fuel system down with 3 walbros injectors (two additional ones bung welded into intake) and a controller for them as well and i have oversized valves in there
Slow66
Authorized Seller
Contributor
Joined
Apr 3, 2005
Messages
1,457
Likes
Location
Newington, CT
#12
I'm not implying you don't....Just take whatever # you have in your head that you think its going to cost to have a reliable 1000whp 7m. Then double it, and you might be in the ballpark of what its going to cost to build one, assuming you do everything yourself. Its really not all its cracked up to be....i kinda regret doing a bunch of expensive custom shit to eventually make over 1200hp on a 7m, I'd much rather have kept my 600hp one together and used this $$ for a house or something....
Slow66
Authorized Seller
Contributor
Joined
Apr 3, 2005
Messages
1,457
Likes
Location
Newington, CT
#13
You'll need at least 1200cc injectors, 1600 would be erring to the safe side, but may not be a bad idea....
3 walbros is a bad idea IMO, you shoudl go with a Weldon, with its controller, along with a sumped tank, -10 dual feed fuel rail, weldon reg, etc....
Idealsupra
Authorized Seller
Contributor
Joined
Messages
2,390
Likes
Location
Orlando
#16
i dont want to sound like an asshole... BUT if you have to ask for a parts list for it... then youre better off just dropping it off at a shop and saying build me a 1k hp engine and paying them money when they ask for it.
HENRY SIEMON
Dont be scare
Authorized Seller
Joined
Nov 13, 2006
Messages
Likes
Location
San Juan, PR
#17
what about ceramic coating on top of the pistons and valves , balancing the rotating mass ,, oil pressure,, tilton cluch or something strong,, you will go with underbuckets shins or one piece lifter like echo lifter ,, ???????????????:aigo::aigo::aigo:
selfinfliction
Authorized Seller
Joined
Dec 11, 2007
Messages
434
Likes
Location
ky
#19
hey i finally seen one of these threads!!! boostlee told me about them when i first came around last month :biglaugh:
Dan_Gyoba
Turbo Swapper
Authorized Seller
Joined
Aug 9, 2007
Messages
1,836
Likes
Location
Alberta
#20
I'd be somewhat worried about the crank/flywheel bolts at 1000 BHP, let alone 1000 rwhp. I'd be expecting that there'll be crank problems. Add at least a forged crank to the list, possibly custom (JZ flywheel?)
89mkiii18
Authorized Seller
Joined
Sep 28, 2006
Messages
15
Likes
Location
st pete
#22
not true i can work on the car i wanted opinions
selfinfliction
Authorized Seller
Joined
Dec 11, 2007
Messages
434
Likes
Location
ky
#24
so should i look more foward to a streetable 600-750 maybe? still as fun? but more reliable?
500whp is what i'm shooting for, i did some looking around about a week before i decided what to do with mine. 500ish was in my price range of $4500, that didn't include a tranny rebuild though, or an ffim. so tack on another $1k already lol
i would love to build a monster car, but i am also a realist and would rather have things done correctly the first time.
Nomad707
Im From The Bay
Authorized Seller
Contributor
Joined
Mar 14, 2007
Messages
1,039
Likes
Location
Santa Rosa, California
#25
7m has a crappy flowing head.. fix that first...
get oversized valves, get a nice set of cams, and you will have to do something about intake, as well.
port and polish the head... alot.
GrimJack
Administrator
Administrator
Authorized Seller
Joined
Dec 31, 1969
Messages
12,377
Likes
Location
Richmond, BC, Canada
#27
Stock crank will hold it, Mibrum hasn't twisted a crank since he fixed the fuel wash problems, and he's well over 1000.
Go to http://7Mpower.com and have a look at the writeup there by Will Neely.
You will absolutely need new flywheel bolts, Duane snapped his at ~800. You'll need a better harmonic balancer on the front, too, talk to ATI about getting one custom made.
I suspect you'll need new bolts on the driveshaft to rear diff interface, too.
There's a crapload of other stuff you'll end up needing - as suggested earlier, have a look at some of the already existing high horsepower builds, that will give you an idea of where to start. Remember you're shooting for even higher numbers, so everything will have to be one step up.
Oh, and one last thing - be prepared for a lot of stuff to break.
7Mboost
7M Powered
Joined
Aug 15, 2006
Messages
2,201
Likes
Location
Gainesville, FL
#32
You'll need more than 1 ssqv, I'd just go with a Tial. 3" intercooler piping, 4" coldside. 4" exhaust, and a bigger TB, and some amazing tuning.
Dutch7m
7m for live
Authorized Seller
Joined
Jun 3, 2007
Messages
75
Likes
Location
The Netherlands
#33
i once thought that making a big hp and still reliable 7m won't be that difficult and expensive , but i only can say, forget it, it will take a load of research, a really good engineshop that really know what they are doing and really really deep pockets.
I really am a 7m fanatic, but if i had to do it over i would go with a 2jz (and i'm not even half way with my 7m project, and my powergoals are half of your 1000hp plans).
Authorized Seller
Contributor
Joined
Messages
38,726
Likes
Location
#34
A "genuine" 500+rwhp 7M that can be daily driven at 500rwhp without changing things for the dyno is a handful and great fun.
Reliable 1000rwhp driver.... as much as I'd like to see it happen it's a HUGE ask.
Authorized Seller
Joined
Messages
14,974
Likes
Location
That's what I said, but of course mine wasn't as eloquently put as yours was........:biglaugh:
Dutch7m
7m for live
Authorized Seller
Joined
Jun 3, 2007
Messages
75
Likes
Location
The Netherlands
#36
pulling 1000rwhp with a 7m is possible, but reliable now way :nono:.
buldozr
Authorized Seller
Joined
Jan 9, 2007
Messages
362
Likes
Location
North Texas
#38
powerglide 2spd auto and about a 5k stall, that ruined the street fun part. Anyone know if the r154 can take the abuse??? High HP 1JZ/R154 guys dont count, not enough torque to break it... :sarcasm:
GrimJack
Administrator
Administrator
Authorized Seller
Joined
Dec 31, 1969
Messages
12,377
Likes
Location
#40
It can't. Will Neely has been quoted as saying that he could peel the teeth off the gears inside the R154 like pulling corn off a cob at will, and he was a lot lower than 1k.
You might be able to *make* it hold.
